Front Suspension Upgrade
This is a great question and has been talked a lot about - everyone seems to have their favorites - I too want a better front end, I have read till I am blue in the face, Still I am not convinced to fork out all the $$$ - I bought the Low, after 200 miles, pulled the front forks and rear shocks.. (rear was a LOT easier) I went with Works performance on the rear and very happy so far. Had them on my 04 for 10 years and they worked fine for us... Now the front... I have read, studied emailed and talked to so many people. I was about to pull the trigger on the Axeo but after talking to a few people, lowered the front and still firm - but they liked that..
on my front, I took the LOW forks - wrapped them in a towel and stored them in my closet.
went on Ebay - got two take off lowers for $40 shipped - had them chromed and got the internal from Boardtracker HD - got the springs from Progressive - just the spring kit... its OK and better than stock but still not to my liking.. One of the biggest issues is Labor for the front.. I can take the forks off no problem - actually pretty easy but I still have to pay my Indy to take them apart and 'Try' something else - lot of work and money just to try something.. The Axeo installed will be a LOT of Money and I am Not convinced it would be worth it...
Please, change my mind, lol
I'm running the Legend Axeo standard height on my 15 Ultra and so far love them. Couldn't afford the Ohlin fronts. I have Ohlin #3-3 on the rear and they seem to work well together. You can get the Axeo from Iron Aces for less than the $750 posted on most sites and they are good people to deal with.
http://www.ironacesspeedshop.com/leg...-davidson-flh/
One of the biggest issues is Labor for the front.. I can take the forks off no problem - actually pretty easy but I still have to pay my Indy to take them apart and 'Try' something else - lot of work and money just to try something.. The Axeo installed will be a LOT of Money and I am Not convinced it would be worth it... Please, change my mind, lol
here is one link that made me stop and re-think
https://www.hdforums.com/forum/touri...gend-axeo.html
here is another good read
https://www.hdforums.com/forum/new-r...touring-4.html
agreed - I watched my Indy... what I do NOT have is a clamp to hold the upper tube so the top Allen can be taken out... Also - as you have learned - finding an allen to fit that top nut is a Bitch, lol and don't forget that bottom allen.. I now own those... Still on the fence with the Axeo.... I am learning more and more on suspension. for you how did you set your sag/preload?
It also basically eliminates front end dive under heavy braking.
FYI I have the standard length not lowered.
what I do NOT have is a clamp to hold the upper tube so the top Allen can be taken out... Also - as you have learned - finding an allen to fit that top nut is a Bitch, lol and don't forget that bottom allen.. I now own those... for you how did you set your sag/preload?
I ordered the top & bottom Allen sockets before I started this task (thanks to this forum)
For the preload, I took a happy medium of me solo (4 turns) & with 130lb wifey +gear (8 turns) and set it at 6 turns
I used the lower triple tree and pinch bolts as my clamp to break the top cap loose.
