Magnetic Traffic Light Changer
I was wondering if anyone has tried or is using a magnetic traffic light changer? Just wondering if they work. I have trouble at certain lights tripping the sensor. I have read that you can lower your kick stand, does that work? I hate to run them, but sometimes I have no choice, and I don't need a ticket. Thanks for any help
under the pavement is an inductive loop- a coil of fine wire.
when a ferrous metal like a bunch of steel goes over the loop, a small amount of current is produced- and that "should" trigger the light control.
it is not weight or mass or anything but a bunch of steel- more aluminum and plastic in vehicles make these less likely to trip than my 66 Cadillac...
IF you drag a piece of steel ( kickstand) along one of the lines you see cut in the pavement or a magnet- you can cause the light control to start thinking about changing the light.
I have magnets on my left boot, and I will drag my foot as I approach the stop.
so you can try to trick the system.
some areas use light sensors on the traffic lights which are meant to sense oncoming firetrucks, cop cars lights etc.
flashing you highbeam can sometimes trigger these...or at least it gives something to do while waiting
if you have magnets, you will pick up all kinds of cool stuff- I put a piece of tape over which I can peel back every once in a while to discard the nails, screws, washers and filing I pick up
- unfortunately many traffic engineers place these loops WAY OUT IN THE CROSS WALK- which cause cars to creep out into the crosswalk in order to make the light change- duh !
mike
mike
BobRed0965 (06-28-2016)
