Toe shifter stripped
So on my way home yesterday my toe shifter pushed down past the point of where it should have. Last night I made sure the allen bolt securing it was tight. And it was really tight, started to strip the bolt when tightening. This morning on way in to work it's now just flopping up and down now. Thankfully the heel shifter is getting the job done for me for the time being. I haven't had the time to pull it apart yet but wondering if it would be the toe shifter that stripped or the shaft it connects to? What do you think?
Pretty common. The shifter lever is purposely made with a softer medal than the shaft to fail in accidents. Once they start to fail, it's pretty much over for them no matter how hard you torque them down. It happens to most of us.
Be sure and torque your new one down to specs and use blue Loctite on the bolt.
Beary
Beary
Beary
Beary
Received 47,786 Likes
Odds are it is the toe lever and not the shaft, however close inspection will verify. It's no big deal to replace either/both items ( being a 2006 I'd recommend both and be done with the job ) By your signature your scooter is a 2006 ?
Toe Lever ... #27 33895-82D SHIFT LEVER (chrome)
Shaft #23 ... 33709-82A SHAFT
Pinch Bolt #3 ... 3275 SCREW 5/16-18 X 3/4 socket hd. (Grade 8) ( get two )
http://www.stcharlesharleydavidson.c...ER%7c%7e1%5cFF
