Wrong barrel key used
Old 07-17-2016, 10:25 AM
Speleo's Avatar
Speleo
Speleo is offline
Default Wrong barrel key used
My son locked up my bike, using the wrong barrel key in the ignition switch. Initially it locked, and the key would not turn nor could it be removed. Got the switch to turn to the on and acc. position, but key will not turn in the lock assembly to be removed. This key in particular, is for the tour pack lock that was purchased after the bike. They look very similar, but not close enough apparently. The cylinder will not turn, to allow removal of the whole assembly. Am I the only dumass with a problem like this?
Thanks,
Speleo
Old 07-17-2016, 12:30 PM
timbo141's Avatar
timbo141
timbo141 is offline
Well now is the time to get everything keyed alike as you probably have a damaged ignition lock.
Not the end of the world but you probably need to get your dealer involved.
Old 07-17-2016, 01:01 PM
Turbo Turtle's Avatar
Turbo Turtle
Turbo Turtle is offline
If you can ride it or remove the switch, (easy enough) a "real" locksmith should be able to remove the key without damaging anything thus saving the switch housing. As a budding smithy myself, I see no reason why it would be held in the switch for any reason, unless for the rare reason the key is out of alignment with the pins. Squirt some Tri-Flow into it and jiggle it aroud a bunch. You might be good.
If you extract the key and the switch is out of alignment, (can't use the correct key) you can grind off the tip of a spare key and insert it into the lock aligning the pins from your key to how they are situated in the assembly, and correct the timing of the tumblers. Good luck and let us know how it works out.
BOB
Old 07-17-2016, 04:55 PM
head's Avatar
head
head is offline
I did the same thing with my 06 RK about a year ago. Accidentally put my added saddlebag key in my ignition. It allowed the switch to work but then the original key wouldn't fit right. Then the whole cylinder pulled up out of the ignition switch. I could/should have called a locksmith to key them all together. I just decided to get a new ignition switch and have the black cover on one key and not the other.
Head
Old 07-17-2016, 06:41 PM
Johnnyh14's Avatar
Johnnyh14
Johnnyh14 is offline
Barrel key ignition switches in Harley's don't last forever. I replaced my main key with an aftermarket when it went bad for the second time. First time I had to pull the fork to change the fork lock too. Easier to carry two keys.
Old 07-18-2016, 05:05 PM
sn95bullitt's Avatar
sn95bullitt
sn95bullitt is offline
Tour pac lock is $29 keyed alike to the bike from HD
Old 07-20-2016, 12:55 AM
mcain49's Avatar
mcain49
mcain49 is offline
Thanks,
Speleo
No, there are other dumb asses around who've done the same thing. I inserted a barrel key from my lockable lower compartments into the ignition switch while the handle bar lock was engaged, and unknowingly turned it until it was jammed in the switch. There I was in the parking lot at Lowe's with my handle bars locked up and a key stuck tightly in the ignition (adding to my pleasure was a highly pissed off wife). I went back into Lowes and bought a pair of channel locks and used brute force to turn the key/switch enough to release the handle bar lock while completely ruining the switch in the process. After overpowering the switch, I was able to start the bike and make it home. That little mishap cost me $150 to replace the ignition switch with my key code. Bet your *** I marked the keys to my lowers compartments to prevent a reoccurrence.
rmurry
08-08-2018 12:00 AM
Bikerpipes
07-29-2018 08:10 PM
Spatenkopf
EVO
05-30-2015 12:25 PM
pseudolus
06-07-2011 12:21 AM
e6fmf
Electrical/Lighting/Alarm
11-13-2010 08:41 AM
Quick Reply: Wrong barrel key used
