Timing Chain Tensioner Pad Inspection
Got the cover off with a steak knife with serrated blade and hammer tap. Came right off with no damage. Didn't use the heat gun.
I have attached a picture of the outside cam chain tensioner pad. Had to use a mirror on the back one to inspect it. Real close to the same wear. I measured the wear at .035" to .040". Not really that bad for 50,000 miles. Specifications call for no more than .090"
Would you change them?
That looks close to what my outside shoe looked (last winter).
Inside was thinner, but on top of that it was very brittle.
While I was in the process of pulling the pin holding it open it closed (back to tension) and the out side portion cracked. It was not a full snap back (I caught it part way). I also went with the CYCO tensioners.
Outside shoe tension spring is in the direction of cam chain travel. Inside shoe tension spring is against the direction of cam chain travel. Poor design.
Two critical things pump alignment and making sure not to shear the o-ring on the bottom(scavage). I had to do mine twice. Also having proper tool for pulling inner bearing's. It's better if you have access to press for the outer But bearings been done with out them. We have a huge arbor press at work that I used.But that's if you change bearing's too. That's what went bad on mine outer. The inners can trash the crank if the go, so it's recommended to atleast change those to the better full bearings.
I align with out tool also to not shear o-ring. Tip from this site, was not to put pump on first like book says but to install with out o-ring then cam plate this is to get it aligned. Now snug four bolts take off put o-ring on with oil, now reinstall, get some bolts on plate. Now this is to fine alignment crack the four pump bolts loose and turn motor over a couple of times so pump can find center. Good to go but check o-ring with a dental mirror as you can see if it was squeezed out with out it. It's to hard to get pump straight on with out the cam plate.
