Dumb Question - Electra Glide Starting Procedure
I've got a 2012 Electra Glide Ultra Limited. Went out to start it for the first time this year (I know..I know).
Put the key in my pocket (it's a proximity key to let the bike know it's you), kickstand up,
gear in neutral,
switch to on,
clutch in (I don't think it makes a difference in neutral),
ignition switch turned to ignition.
The battery has always been on a tender and seems fine, all lights and horn, etc. work. When I press start - nothing.
Am I just forgetting some boneheaded simple thing in the start process, or do I have a problem? The last time I rode it was for a service last Fall.
gear in neutral,
switch to on,
Thanks, After the first failure, I changed the battery in the key fob. To verify it worked, I turned on the ignition with the fob back in the house, and all the lights flashed. When I put it back in my pocket, and tried again, I got no warning flashing lights, so I'm sure it's ok. And I did have the kill switch set to on each time.
Received 1,504 Likes
