Voice activation for rider to passenger
Hi
I recently purchased a left over 2015 Electra Glide Ultra Low. The bike does not come with a push to talk modular for the driver. The passenger has one.
I am told that the mike turns on and off by voice activation. Does anyone have any experience with setting the mike so I don't have to scream into it to activate it. My 07 had the handlebar button and life was good.
I really very much depends on how you ride: open helmet, 3/4 helmet (with shield down or up), the speed you travel - you will need to adjust, as was already said, the microphone gain. In your case I would start with the bike not running and make it work in that situation. Then you can tinker with it when riding.
Keep adjusting the VOX setting- too sensitive and the intercom opens with wind and engine noise, especially as you speed up. Not sensitive enough and you have to talk loudly to get it to activate. Make sure to put the mic right in front of your mouth. I set mine so that wind noise doesn't activate it at speeds up to 80 mph, that's about as fast as I ride. Going slower, just have to talk right into the mic.
Yes they have CB's and PTT button on the right side is just for that, the intercom is voice activated and has stated the VOX has to be adjusted for riding conditions. The key to getting right is to ensure the mic is direction in front of the mouth, like riding on the lower lip, if not then communication becomes difficult. I constantly have to remind the wife to put the mic to her mouth when talking, otherwise it breaks up and if I turns the sensitivity up then it starts picking up wind noise, just a balancing act once set it does work nicely.
