External Breather Vent Question
SGJay / Crimson 13,
Please comfirm...you guys are using 3/16" ID (inner diameter) vacuum/washer fluid hose? I couldn't find 3/16" ID vacuum hose when I was in the auto parts stores, and ended up using 2/16" ID (5/16" OD) vacuum hose which I connected to the bottom of the "T" adapter in the stock AC on my '14 Road King. At the time, I was concerned the 2/16" ID might be too small, however it does puff air well when engine is running. I get a little condensation from the end of the hose but no noticeable oil.
Do you guys think the 2/16" ID is too small? Maybe I should look for 3/16" ID vacuum line and swap it out. Here's some pics of my TB bypass...
Thanks
Thanks
