Primary fluid
Old 07-30-2016, 02:27 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,077 Likes on 1,906 Posts
Originally Posted by seniorsuperglideE8
There warnings about low primary levels in most HD service manuals and how that may affect shifting or finding neutral. My 2013 Road Glide Ultra calls for 38 ozs. when doing a normal fluid change and that's what I do.
My Manual says:
CAUTION
"DO NOT" overfill the primary chaincase with lubricant.
Overfilling can cause rough clutch engagement, incom-
plete disengagement, clutch drag and/pr difficulty in
finding neutral at engine idle.
I am reasonably convinced you got it "backwards"
Old 07-30-2016, 03:51 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
Originally Posted by bdtaylor1979
Why did they change the primary cover in 2016?
They went to the narrow cover
Old 07-30-2016, 03:58 PM
sixguns's Avatar
sixguns
sixguns is online now
Received 1,458 Likes on 755 Posts
to help short people get their feet on the ground.
lafontaine22@yahoo.com (07-15-2018)
Old 07-30-2016, 04:01 PM
Tired's Avatar
Tired
Tired is offline
Received 4,407 Likes on 1,685 Posts
I always use 1 qt. Have for many years on several different twinkies with no problems. FWIW, your clutch would be perfectly happy dry. The lube is for the chain, compensator, and to help with heat from the stator.
Several aftermarket clutch companies recommend as little as 16 oz. with their clutches. Just enough the chain can pick it up and toss it around.
Old 07-30-2016, 04:03 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Alrighty then.
Old 07-30-2016, 06:19 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
in my past primary fluid changes, i used 38oz., so when my indy said 32oz was okay...
that is the reason i posted in order to see what others may have come across variations in fluid use etc.
Thanks.
Old 07-30-2016, 07:47 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
I run ATF and use 32 ozs. No problems
Old 07-30-2016, 07:54 PM
7roper7's Avatar
7roper7
7roper7 is offline
Drain it, dump in 1 qt, forget about it. The chain will absolutely get all the lube it needs.
Clutch will be happier.
Old 07-30-2016, 08:14 PM
stoneybagger's Avatar
stoneybagger
stoneybagger is offline
Default 05 road king manual recommends
Do not overfill the primary chaincase with lubricant.
Overfilling may cause rough clutch engagement, incomplete
disengagement, clutch drag and/or difficulty in
6. Pour 32 ounces (946 ml) of Harley-Davidson PRIMARY
CHAINCASE LUBRICANT through the clutch inspection
cover opening.
have been told to fill primary oil up to bottom of clutch inspection cover.
seems to be showing this in the pic below from manual also.
stoney
talkingrock (08-02-2016)
Old 07-30-2016, 08:46 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,557 Likes on 5,153 Posts
He is an INDY what does he care what you put in it. I would nor recommend listening to him.
Primary cover change : Simple in 2016 they made the narrow Primary standard on all Touring bikes. The narrow Primary cover shape and designed required a different cover.
Quick Reply: Primary fluid
