110 ci kit woes!
110 ci kit woes!
So....I was installing the front piston into the cylinder when I broke my #2 piston ring. Well, I called my local stealership and they advised me I had to buy the WHOLE rings set...to the tune of a $118.37! ..WTF!
I COULDN'T BELIEVE IT!
Does anyone have individual part numbers for the harley piston ring set 21951-11?
Order them online: https://shop.newcastlehd.com/part/21951-11 $47
That part number is for one piston set. You might be able to contact Mahle to see if they could get you a single since they make the pistons/rings.
