Perhaps I May Have Found the Source of a Long Elusive Squeak!
I've had a "squeaking" going on for two riding seasons. I've had the primary opened up in the past, and found that the nut on the compensating sprocket was very loose (finger tight). I torqued it, and thought for sure it that would solve my squeaking problem. Nope! About a week ago I tried to adjust the primary chain, and put HD Primary fluid in. It made it louder! I was previously running Amsoil 20W50. So, with that said, i will be sticking with the Amsoil. Ok, so i took the entire primary cover off, and checking everything thoroughly i found that i was able to wiggle the clutch assembly back and forth just a hair. a very minute amount. However, when i was trying to wiggle it, it was enough to put slack in and out of the chain. Thankfully it's not the main bearing. It seems like it's the clutch hub bearing. Would this cause a squeaking noise? It was most heard when the engine was thoroughly warmed up, and i was somewhat lugging it (ie:40mph in 5th gear). It's all apart, so i guess it's going to get replaced, and hopefully it takes care of the squeaking that i have been trying to find for over a year! opinions? thanks!
I usually do not lug the engine like that. I was just using that as an example of when the squeak could be heard the most. I purchased it with approximately 20,000 miles on it. Whoever owned it prior to me probably did some goofy stuff to it. When I disassembled the primary this time, I had a hard time getting the comp. loosened. I had to heat it a bit with a torch. I took care of most of the issues with the bike. "the squeak" is the last thing. The rear wheel hub was even shot (the spoke holes were all oval) I ended up putting stock Road King wheels on it, and it looks great. I've also done the cam chain tensioners. Hopefully I will have it back together by the weekend, squeak-free!
SummitRK
08-16-2016 03:19 PM
cerati666
08-19-2013 05:35 PM
