inside 2017 primary
Check out Baggers Mag article on the new Milwaukee 8. Lots of cutaways of the new engine including the Comp, Primary and info on the new clutch. http://www.baggersmag.com/harley-dav...ilwaukee-eight
Is the clutch really new, or is it the "Assist & Slip" from the Rushmore CVOs & Low models?
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
I see the compensator is going to require a new tool to remove. Looks like an oversized torx bit to hold the shaft stationary while torqueing/removing the nut.
Also they didn't want to show the chain tensioner in the cutaway. That would've been nice to see.
I don't know what that torx is for but there still is a big nut there. There's no way that you could tighten that torx as much as a compensator needs to be tightened without rounding it off or breaking your bit.
