2013 Ultra Limited Front Brake Dive?
Just recently got a used 2013 Ultra Limited. Does this bike have a front brake dive out of the factory? I can't imagine the previous owner changed it for softer ride. The rear bottoms out even at 35 psi, I'm going to add another 5 to make it 40 psi for two up riding. Any suggestions.
Thanks
Thanks
a new bike is a black slate- a used bike may have previous owner mods or just wear.
for the rear if you have 13" shocks- follow the manual and try that- I ran mine at about 25 pounds most of the time for my weight with gear and junk in the saddlebags- and the tourpak off- with my wife and tourpak on..about 12 more pounds.
add air until it doesn;t bottom out and doesn;t top out
the front end may need heavier oil in it for you weight, roads and preference.
get the service manual it'll pay for itself 1 st time you use it
2 newbie mistakes:
the oil drain is on the FRONT of the oil pan facing forward- the tranny drain is towards the back of teh oil pan & faces the ground.
if removing the rt side controls a shim MUST be used on the brake light switch or it will break.
mike
2 newbie mistakes:
mike
I own a 2013 Ultra CVO, and since the day I purchased it, the nose dive when braking was significant. I replaced the front and rear with Progressive's. I don't recall the number of clips. But I had the bike lowered an inch with both. The front doesn't dive any longer but the ride is a little stiff. Did the same thing on my 05 Ultra after a couple of years dealing with it.
Joe
Joe
Install proper rated Race Tech springs with RaceTech Emulators. 2017 Touring bikes now have a basic, non adjustable, similar setup as Race Tech Emulator Gold Valves.
"The shocks are much improved and so is the fork. Showa has come up with a novel approach to fitting flexing-disc damping control. It’s not a conventional cartridge arrangement, but what it most resembles is the long-running Race Tech Emulator, which converts a damping-rod fork to have cartridge-like damping character. In this case, a pair of deflecting-disc valves reside in a chamber placed atop a conventional looking damping rod. They take over some of the rebound and compression damping so that the fork doesn’t have the harshness of a pure orifice-controlled device. But it’s also simpler and probably less expensive than a conventional dual-cartridge setup. There’s no adjustment for the fork, and no way to change damping settings at either end. Maybe some day…"
