Hhi caliper dragging
I got a single sided 6 piston on my 13" rotor and the other day I felt the bike slow down really fast. I grabbed a fist full of front brake and let it go really fast and it seemed like it went away. I got 700 miles to do over the course of the weekend so I decided just to check it. The rotor has small grooves from the caliper dragging. I got a 13 ultra and I'm unsure what to try first. I bled the brakes once and next up is shims but I'm unsure if the caliper is actually returning to its original state after I grab the front brake.
From your description, it sounds like the brake pad is cocking, creating the drag. Your brake application re-squares the pad, fully releasing it. Until it next drags or wiggles itself into a cocked position.
I know of various 6-piston calipers, but not one that has 6 on one side only. That would be a very long caliper. Are you sure you're describing this correctly?
I have one Rotor and Piston on the left side. (Single Sided) Sorry. Pad may very well be cocked because I had no problems dragging until recently. Ill remove the pads and clean all surfaces, reseat the pads and hope for the best. I can see the rear of the pad sticking out and not contracting after the lever is released. Wheel bearings are good.
