idle adjust
your idle should be 1000 rpms +/- 50
this "high idle" is needed to keep oil pressure and volume high- the oil actually removes heat from the hottest parts of the motor- resulting in a net cooling.
there is an idle adjust which can be done through the backing plate once the air cleaner cover is removed -
mike
mike
