Cleaning Inside Of Gas Tank?
Received 4,891 Likes
White vinegar (given 24 hours or so) will eat away any rust or other contaminants, but will also be safe on the paint. I did 24 hours with the vinegar (3 gallons worth), then two rinses with water followed by a gasoline rinse. Installed the tank and filled it up with clean gas, no problems.
This was a 70 year old tank that looked 70 years old, been on my Flathead all season, only cleaned the fuel filter once, about a week after installation. Filter has been normal since.
Sometimes the easy solution is the best.
ive cleaned a few tanks in my time with "the works" toilet bowl cleaner. Ive had tanks completely full of rust on the inside come out looking shiny like new. Fill the tank with half warm water, then pour in a whole bottle of that stuff. Pick up the tank and slosh it around and let it sit. Pour that stuff out and rinse it out really well. Immediately take a blow dryer and dry it out, then fog it with WD40 so it doesn't flash rust again. That is very important. Ive had tanks from the 70s that looked hopeless and turned out like new again with that stuff. $1.50 a bottle at Kmart. DO NOT let that stuff touch your paint job. I use to tape over the hole that gas goes in before sloshing it around. If you accidentally get any on your tank immediately wash it off. Works better than any other product ive seen.
