Progressive Suspension 944 Ultra Low Shocks
I had a set of Progressive Suspension 944 Ultra Low shocks install at their booth in Rapid City HD. They set the sag and I took off for home. All I can say is that my bike now feels like a hard tail. I have tried every means of contact with them but to no avail. The most sag I can get is 1/8 of an inch and that is with zero preload. Any suggestions? I have a 2013 Street Glide.
un4gvn56 (09-27-2016)
Once standard springs were installed, not only was the ride much more plush where it needed to be, I was able to set sag easily. Moreover...I think that there was a break in period even at that. After about 1000 miles my shocks seemed to perform better than when the springs were brand new. Might be my imagination, but I am at least happy with the way they perform.
Good luck!
Give them a chance, they'll make it right.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
I put the 944 Ultra Low Shocks on my 2021 Road Glide Special and they did lower the bike apx 2". I've adjusted 944UL's from 1 line to 8 - they will bottom out if the road is bad enough at ANY line. I have a 'Saddlemen Road Sofa' which helps with potholes (we're in Omaha, NE). I do low speed course maneuvers and have noticed the primary guard is scratched (I do have Motorcycle Drop Guards - including the primary guard). More scraping occurs at the lower line count (1) than the higher (8). The 'floor boards' are NOT scratched so the guard is doing it's job. (so with 944UL's the primary gets scratched before the floor board bottoms) I'd rather ride higher at 8 lines than 1 line! Only 2000 miles on the shocks so maybe they will break in and soften up at the higher line count (8). To conclude you are correct is thinking the higher line count is a rougher ride - pray for 'break-in' because the bike height is perfect for me now. (I'm 180lbs at 5.9 31" inseam)
