Gaskets for cam change ?
Most cam kits ive seen come with the cover gasket and the two bearings but i need to find what gaskets i will need for the top as i plan to use the existing pushrods , The parts book shows that maybe all i need is the rocker cover gaskets ? am i missing anything can i leave the breathers in and just pull the rocker plate ?
U tube vids all show cutting the pushrods and replacing rods and tubes which is outta the budjet right now . Looking at the 48H cams
Dave
Dave
Rocker cover uppers and lowers,new o-rings for the pushrod tubes,wouldn't hurt to have the breather gaskets and spongy things handy just in case.I did mine a few months back
by pulling the tank and rocker boxes,the rear rocker assy is a pita to wrestle in and out-you just need to be patient with it...
Up top you'll only need the rocker cover gaskets (upper) and the push rod tube Orings.
I would just get a James or Cometic Cam service kit. It has everything you need gasket wise to do the job. Includes new breathers too.
http://www.ebay.com/itm/JAMES-GASKET...JX0IRX&vxp=mtr
