Heated clothing voltage issues?
Example, mines an FL family EFI bike. I know that stock, I have 39.4 amps available at 1500 rpm, I have 45.2 available at 3000 rpm... The bike uses about 28 amps under normal load. That means I have about 10.8/17.6 left to use.
My jacket liner draws 6 amps , gloves draw 2.20... That's 8.2 vs the 17.6 while riding, so I know I'm safely well under an overdraw threshold.
And that's all more than likely very conservative; I can run two jackets, a pants liner, and two pairs of gloves with no issues; though I wouldn't do that if the bike was just idling there for an extended time. Also take into account what lighting you're running, upgrading from halogens to LEDs cuts the bikes draw way down, little things like that affect what you have available to use for accessories.
I've never needed the high setting, Low is usually plenty.
High 100% - 135°F 2 hours
Medium 66 - 115°F 4 hours
Low 33% - 90°F 6 hours
