I used BOTH derby cover gaskets
2007 FLHX - When I changed my primary oil, I removed the o-ring type gasket and replaced it with the flat type gasket. The flat gasket LEAKED, so I removed the derby cover and reinstalled the o-ring gasket along WITH the flat gasket. The flat gasket's inside dimension is larger than the recess of where the o-ring gasket sits. The leak has stopped!
When I did a search for this topic, I found nothing, so I may possibly be the ONLY person using this method of added protection.
I used the stagger torque procedure. The cover is OEM. The flat gasket fit, it just leaked slightly.
Make sure the cover is not warped by placing on a flat surface. Otherwise the o-ring will work fine alone, in fact I have re-used mine several times with no problem. Just have to make double sure its fully in the groove before installing, I have to hold part of it with my finger as I slip the cover on. Harley has an oil change gasket kit that is pretty cheap and has all the o-rings in it. The gasket is pretty useless.
xcbullet (12-03-2016)
The following 2 users liked this post by lp:
0.0 (09-15-2017),
OldEnuf2NoBtr (12-03-2016)
