Want more power
Old 12-08-2016, 03:14 PM
hdng's Avatar
hdng
hdng is offline
Default Want more power
What CA I do to add ponies to my 95/88
I have changed pipes, headers, jugs ,air filter slight cam but I would really like to get more performance out of my 88. With 95 jugs. Any suggestions .
Old 12-08-2016, 03:19 PM
shorelasHD's Avatar
shorelasHD
shorelasHD is offline
Received 2,858 Likes on 1,270 Posts
If you want better performance, try one of these:
Spending $$$ to make a Harley something it's not is like those a$$hats who put coffee-can mufflers and a spoiler on their Civic. JMHO.
The following 2 users liked this post by shorelasHD:
FattyMcJ (12-08-2016), sabunimwil@gmail.com (12-08-2016)
Old 12-08-2016, 03:21 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Talk to a tuning shop about making further improvements, such as porting your heads, higher CR and a different cam. We have HDF sponsors who will be happy to help I'm sure, with proven tuning packages.
Old 12-08-2016, 03:24 PM
harkon's Avatar
harkon
harkon is offline
Maybe a new S&S mill?
Old 12-08-2016, 03:38 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,356 Likes on 2,613 Posts
Yeah, I'd have to think that once you're at 95, (presuming thus that heads are ported, cams, etc), you'd have to go bigger, drop in replacement is the way to go.
It becomes an interesting cost calculation, what with what we're seeing with M8+cams+2-1, I know its more money to go that way, but you also are making a 2 generation leap in terms of handling, creature comforts etc.
Old 12-08-2016, 05:50 PM
wscott's Avatar
wscott
wscott is offline
Well unless your looking a whopping increase in power but maybe like an additional 20-25HP (maybe even 28- 30hp if your lucky) & 20-25ft lbs trq (maybe 27-28ft lbs + trq) that could get by doing following:
* If you have considerable miles on the motor (esp top end) at the very least pull the jugs to have current pistons & jugs measured to ensure they are still within service spec.
If they pass spec have the pistons cleaned and new rings installed along with jugs ball honed too.
If jugs dont pass spec have them bored to next oversize if there's enough meat leaf to do so along with proper size oversize pistons avail too.
* Have the stock original heads ported along with doing a valve lob to freshen them,maybe larger installed if poss too.
Or maybe it would easier/more cost effective too install replacement perf heads that are already ported with larger valves ,thats up to you or the builder.
* If still running stock compression (9.0-9.5) could maybe increase compression to 10.0-10.5 compression while your at it.
* Install a considerably hotter cam with more dur & lift that matches co mpression ,bikes wt & your riding style too.
But not so much cam (duration!) it kills lower rpm engine perf & or overall driveability.
* Install a tuner & have it properly dialed in timing & fuel calibration wise for best pwr/trq & overall performance.
BTW, I am not sure of your bike's age/yr so dont know if it has a carb or EFI but either way ensure which ever you have is also optimised/properly dialed in for best perf too
* If in the budget could even swap out current mufflers (maybe even front head pipes too) if there is another ex system avail for your bike that's got a proven performance gain over the current ex system on your bike.
Could call Scott @ Hillside Cycle & Machine,see below for contact info.
Let us know what you decide to so.
Good Luck.
Scott (BTW,i am not the Scott From Hillside cycle)
HILLSIDE MOTORCYCLE & MACHINE, INC.
Harley-Davidson Speed & Service Center
Munnsville, NY
M-F, 8-5, 315-495-6650
www.hillsidecycle.com
"Repairing broken torque curves for 30 years."
Old 12-08-2016, 06:26 PM
94 ultra's Avatar
94 ultra
94 ultra is offline
You'll poke your eye out with that !
Old 12-09-2016, 08:15 AM
Goose_NC's Avatar
Goose_NC
Goose_NC is online now
Received 4,174 Likes on 1,955 Posts
The only answer to "How fast can I make it" is "How much money you got?".
Old 12-09-2016, 08:35 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
For the best results ask your performance questions here.
https://www.hdforums.com/forum/engin...cal-topics-46/
Old 12-09-2016, 08:40 AM
gipper's Avatar
gipper
gipper is offline
Mr. Brown has given you solid advice, OP. Call Hillside or Fuelmoto and ask the guys than will give you empirical data having squeezed as many ponies out of a 88 ci motor literally thousand of times.
Based on what you stated you've already done to your motor, looks to me like there's a few more steps that you could take without spending an inordinate amount of money. Especially if you can do the work yourself. But these sponsors on here that make doing what you want to do their profession can advise you comprehensively.
Quick Reply: Want more power
