TMax or PC?
The other shops that are closest to me, keep telling me to go with the 510g, cobra fi 2000 (1500.00 to 2000.00) All the reading I have done, it seems to me that the cobra is a waste of money. I have some suggestions by other shops to go with gear drive and thunder max with auto-tune. Make sense?
The reason many shops state Cobra Fi2000 w/AT is a waste of money under (500.00) is their services are not rendered, no are any other related sales can be made (no profit). It's a plug and play system that I'm currently using and cannot find any problems. 40% more power from idle to redline no hesitation pulls hard throughout the gears, 44 mpg/42 mph 2 up highway. I don't understand why more Harley enthusiast are not using this fuel tuner.
I suppose a fuel tuner needs to be complicated and requires additional $$$, or a technicians insight $$$ or site commissioned promoters $$$ for someone to believe its worth it IMHO.
Heat management system was activated almost every time I came to a traffic light. After installing Cobra Fi2000 w/AT WOW!!! unbelievable power across the entire band. No more HMS!!! No downloads/maps, or dynos required. I suppose it just way to simple and cost efficient to be true!
B Bop
To each his own bro, just trying to open some eyes here! We are good!
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
B Bop
I've had T-Max on 3 bikes. 2 of those my wife and I still have. They've worked well for me. I can change components on the bikes and not have to get a dyno tune every time I do so. Are the tunes the highest optimum tune possible? I doubt it but they run very well and we've been happy with the performance. They are nice if your a do it yourself person.
B Bop
B Bop
1. Look to use narrow band sensors.. Fuel adjustment range limited..
2. Doesn't mess with timing. HD stock download uses too much timing to limit emissions. System will likely work with only limited compression.
3. Only adds fuel. Cannot dial in starting parameters..
4. Cannot set Fuel injector timing.
5. Cannot adjust for injector size change..
They are probably OK for a stage 1 and possibly a few cams..
I favor the TTS. I have two with it and two with the now defunct SE race tuner. They are essentially the same systems as TTS developed the H-D race tuner for them. They have parted ways since then.
But I don't know about the other tuners as I have never used them. The one exception is the Cobra FI2000R-CL which for the money was perfect. It ran a power afr in closed loop.
They are not made anymore and Cobra only has the Power Pro or whatever they call it and it only operates in open loop besides costing much more than the old closed loop model.
I am to timid to mess with either the TTS or SERT. Maybe I will get brave some day. I have a laptop and the cables just sitting in a box.
My M8 has the new H-D street tuner. It is good for retuning after the various stages. But I let the dealer do it.
Absolutely Cobra Fi2000 w/AT is best for stage 1 with cam upgrades, buuuut isn't that the majority of Harley owner's? If that is the extent of your hobbies can understand pouring your money into your scoot, but many including myself are not going beyond stage 1 w/cams, as we need to distribute play money in other categories, boats, street rods, 4 wheel off road, 1961 fuel injection Corvette etc., etc.
If I was rich like Donald Trump then all my toys would be maxed out correct!
B Bop
B Bop
I've never had the Cobra, what I've read I didn't like. I have had TTS, TMax and currently use Power Vision. I found the TTS was difficult to "auto tune" but it could have been me. The Tmax worked well for me, I'd run an "auto tune" twice a year and the bikes ran good. I changed to PV on my wife, Kim's 2015 limited and when I bought a used 2014 for myself it also got a PV. The PV is the easiest to use so far and my MPG and power are the best by far. I bought the PV's and installed a map for the stage one one each bike then ran a few Auto Tune sessions. The bikes run great and I don't feel the need to have them Dynoed.
Good Luck
Bill
Good Luck
Bill
