Knocking noise at idle when engine is hot
I've noticed a few times a knocking sound after a ride coming from I think the front of the bike when engine is at idle. Have only noticed it after a ride when engine is hot and turning it around in my garage. Any ideas? I don't know if it's coming from the engine or something is loose and hitting on something. Again, doesn't do it all the time.
RE: Knocking noise at idle
Well get a mechanics stethoscope (about $10).
go around the whole bike. Where the noise is loudest
is where to look.
I would also check the engine while it is idling.
Most engine knocks are described as a pinging sound.
But they can also sound like a actual knock, when detonation
is happening.
Sudden slow down to an idle with a warm engine can cause engine detonation.
Engine heat momentarily increases at this time.
But hopefully it is an external thing that is loose.
is where to look.
is happening.
I've only noticed it a few times. When I have heard the noise is when I'm pulling in the garage after a ride and manuevering it around. Could it be I'm lugging it while engine is hot and causing the knock? If it is engine detonation at idle when engine is hot, is it something I need to be concerned about?
RE: Knocking noise at idle when engine is hot
ORIGINAL: sparky_mo
Also check the stabilizer links too.
