tour pck questions
tour pck questions
So on a 2010 ultra limited, I am going to want to be able to take off the tour pack(large top one) Would like some feedback on how to do this I talked to a HD parts guy and to get the entire kit quick disconnect he was talking $800!! Any help on this would be great. Thanks
Yeah, the kit is the way to go. Expensive, but without it, removing the tour pack quickly becomes a hellish nightmare.
If you want the parts, go to http://boardtrackerharleyonline.com and get 20% off, free shipping.
Never did it, but helped a few others.
They liked being able to take the Tour-Pak off.
Using HD parts, at the very least you would need the “Conversion Kit” (Part Number 53246-09C, list $549.95) and the disconnect wiring harness (Part Number 69200181, list $99.95).
That’s $649.90 in parts alone.
That is of course assuming you don’t have an amp under that Tour-pak.
But if you go that route, some advice: the first few times you take it off make sure you have someone to help you.
After you get used to doing it you should be able to take it off by yourself without any problems.
many of us who bought the detachable kit...realize during install that bolting and unbolting the T/P takes about 30 minutes.
the detach kit is great if you are on/off/on/off all the time.
mine is off almost all the time, it goes on when I tour...I coulda saved a few hundred bucks...ooops!
Mikw
Mikw
My Rig didn't come with a tour pack, but knew I needed one for touring and Momma.
My tour pack has the following: pod speakers, side marker LED lights, Running-Brake-Blinkers rear LED lights, AirWing rack LED lights.
Came with a Eazy Peazy 1 plug (actually 2 plug, one for led modulator) disconnect set up!
YB
With Tourpak on.
Connecting plug from Tourpak, longer wire for my LED Modulator.
Another view of plug with cap on.
Solo seat, cap shown on plug.
Close up of plug with cap.
YB
With Tourpak on.
Received 47,786 Likes
Mikw
Mikw
Makes a great winter project. Check it out here & good luck!
https://www.hdforums.com/forum/touri...etachable.html
