Help wiring up 2014 Tour-Pak to 2009 Street Glide
I have a 2009 Street Glide that I'm adding 2014 saddlebags and tour-pak. I have triple play and want to carry over the same functions as far as Run/Brake/Turn to my led tour-pak. Brandon at Custom Dynamics is checking if the triple play module will even handle the extra electrical load of the led lights on the tour-pak. I found a video of someone doing this on a 2010 model but with the tail light being on the rear fender on the 2009 the splicing in location is going to be different assuming the triple play module will handle the extra load. I'm thinking with my rear lighting wire diagram and my trusty electrical tester I may just have to jump in there and get busy. Thanks for any direction on this one guys.
Ride Safe!
Ride Safe!
wire in at the plug at the front of the fender
black is ground
blue is run
red/yel is brake
violet and/or brown are turn signals ( if the T/P has them)
if you are a DIY type of guy, a $12 trailer flat 6 plug w/ leds makes this easy- have the 2 plugs mate back by the T/P
mike
black is ground
blue is run
red/yel is brake
mike
black is ground
blue is run
red/yel is brake
mike
black is ground
blue is run
red/yel is brake
mike
I have male velcro wrapped around my "bike" plug, and loop velcro stuck on the top of my shock, I stick the plug there when the T/P is off.
the wiring runs along the fender strut rail and behind the left side cover, then come up under the seat and wired into the bike there
the leds make for easy trouble shooting
mike
mike
traveler
12-17-2013 09:10 PM
Street_Glide_2012
Electrical/Lighting/Alarm
02-13-2013 01:05 AM
