Progressive fork spring rate
Progressive Suspension is evasive on the spring rate for their fork springs and only touts their perception of the advantage of a progressive rate spring.
I am particularly interested in model DA222048 which is a standard height bagger spring.
Has anyone measured Progressive brand bagger spring rates
DS is Drag Specialities
PN - DS222048:
http://www.dragspecialties.com/produ...umber=DS222048
As you can see it is common in most FL's with 41mm forks and billed as the "performance replacement"
Drag does not give the Progressive PN
Progressive offers 2 versions of the 41mm spring: Heavy Duty and Standard
I understand the arguement for linear VS progressive rate springs and would like to know the spring rate on the Progressive brand progressive springs for the FL
PN - DS222048:
Progressive Brand doesn't show a spring progressve rate graph, but they do publish Technical Specs. They show the Standard Duty# 11-1131, but oddly not for the Heavy Duty# 11-1536. You might contact Progressive for the 11-1536 specs
http://www.progressivesuspension.com...-Tech-Info.pdf
chromedome
10-03-2009 09:20 AM
