Bleeding Front Brakes
As I mentioned in my first email, I have a speed bleeder and used it. I also pumped the handle many many times with no effect. I tied off the handle and will see if that has any effect tomorrow. My next step will be to go back into the caliper, pull the pistons and pre-fill that area in fluid before I put them back in. I will also see if I can pre-fill the fluid channel before putting it back on the fork.
Bleed at the banjo fitting on the master cylinder. It's messy, and protect the paint, though if you're running silicone fluid, it won't blister the paint.
Easiest way is to pull the lever, and crack the banjo fitting. You'll hear the air escaping with a snap/crackle/pop sound. Close the fitting, release the lever. Repeat until no more air comes out. Then bleed the calipers in the normal manner.
In any case, I have run a couple of bottles of brake fluid through the lines with the speed bleeder until there are no bubbles at all. I believe that I removed all of the air in the line. Late this evening I found some fresh fluid leaking at the bottom of the caliper. I think that the problem might be there. I'll take it apart again tomorrow night and see if I can find the problem.
The only other thing that I can think of is the handle connection itself. I have not taken it apart to see how it connects to the reservoir and pumps the fluid. Maybe there is a disconnect there that prevents it from pumping properly.
Received 2,524 Likes
Boomer1143 (02-14-2017)
