Bleeding Front Brakes
The air is in the master cylinder most likely. Bleed it first by loosening the fitting, pulling the lever and letting some fluid run then close. Do it about 4 times. Then bleed the caliper. This should take care of the issue, unless you have a leak that is pulling air in. Wash the calipers with clear water, that will remove any spilled fluid.
I believe this is why a couple of people have recommended that I leave the brake handle pulled tight for the night to allow the escape at the reservoir.
I would definitely try this before rebuilding the master cylinder. I have seen this procedure work when nothing else would.
What type of setup do you use for a syringe bleed? Is there a complete kit for it?
Is this the mityvac people like to use?
http://www.harborfreight.com/mityvac...ump-39522.html
L88 (02-14-2017)
It sounds like the OP has tried bleeding the brakes several times. It also seems that he cannot build up any pressure in the system. That may be due to air but it also may be due to a defective master cylinder. I would remove the brake line from the master cylinder. Then I would just place my finger over the outlet of the master cylinder and pump the lever to see if it has any pressure. Just my opinion, but that's where I would start.
