Best horn under $90?
Received 2,524 Likes
Once you make up your mind that want a new horn, this probably won't appeal to you. The horn on my 08 Road King was pretty wimpy. My son bought an 11 Road Glide Ultra and his horn was quite loud. On the back of the horn is a tuning screw with a lock nut. When a horn stops working, often turning that screw a bit will get it going again. Then experiment by further turning the screw for maximum loudness. My horn and my son's horn are about the same volume now. If that isn't loud enough, then spend the bucks for something else.
Big Dave (02-15-2017)
hands down a Stebel Natalus at 139 db. They must have the noise wand right up its hoop to get 139, but still very loud
http://www.ebay.com/itm/Stebel-11690...xX6ZWO&vxp=mtr
Make sure you use a relay. Not only are these bloody loud, but reliable, and at +/- 32.00 unbeatable.
As with most things there are Chinese copies..................
On my RG I have a parade fan in the horn location, so mounted the Stebel using a Kury P-clamp on the front crash bar at my L foot
On the Dyna I split the Stebel into 2 parts. The "horn" bit inside the factory cowbell, with the compressor remotely located under the seat
More than once I have been asked where did you get that horn
Received 8,247 Likes
