Throttlepak vs fuel pak
Received 6,044 Likes
Received 4,879 Likes
Throttle pak opens your. butterfly valve faster than stock on pre 14(?) throttle by wire, bikes. It does not change your AFR.
Fuel Pak and Fuel Pack 3 are tuners. They change your AFR to allow for changes in the air cleaner, pipes, air flow.
The Fuel Pak 3 can, among many other things, adjust your throttle progresivity for faster opening butterfly valve.
i have a throttle pak by vance and hines.
when i purchased my 13 SG, i was appalled by the throttle lag of the throttle by wire compared to my other bikes wired throttles. couldn't believe anybody would put up with it.
seems severely overpriced for what it does though. happy with it since it solved the problem.
