Replacing Amber lenses.
#31
#32
Just got back from a ride so I haven't done much research. I see how the front fender tip lens should pop out but the rear looks like it might be one piece. I also haven't checked out the tail light to see if I could just replace the stock red cover with a smoked cover. At this point I know I could go with front and rear smoked lenses with amber bulbs. I can also get a front fender tip lens that is smoke. Need to figure out what to do with the red rear tail light and red rear fender tip lens. I don't know how it would look with everything smoked except those two things.
#33
in the rear, turn signals can be either amber or red. brakes must be red. so if you add a module to make your turns flash with your brakes, you have to switch the lenses to red ones. (or smoke with red bulbs)
#34
#38
I have smoked lenses also but I went a step further. I painted the inside housing of the turn signals a dark gray color. When the bike is parked they look blacked out. have amber bulbs in front and red bulbs in the rear (run brake and turn module for the rear) No issues on the brightness but looks killer otherwise. Have done this to every bike I have had with smoked lenses.
#39
#40
Not sure what year you have, but I had to replace the entire fender tip light with a smoked LED unit. I have a '13 and the cover is not removable.
Try something like this. The one I have also has the amber blinkers built in.
http://www.ebay.com/itm/DS-Fender-Ti...dYjUPZ&vxp=mtr
front lens
http://www.ebay.com/itm/DS-Lens-for-...ZYaVnU&vxp=mtr
