Burly brand apes and heated grips?
If you use a 27/32 reduced shank drill bit to bore out the grip area about 5 inched deep short of the accessory opening you will still have more wall thickness than stock handle bar and the heated grip will slide on easily. I tried it without boring out and the internal part of the heated grip stuck inside the bar. I did it on a 2016 Ultra Limited with a WO578 Wild One set of 1 1/4 bars.
electra_boogaloo (02-24-2017)
If you use a 27/32 or 55/64 reduced shank drill bit to bore out the grip area about 5 inched deep short of the accessory opening you will still have more wall thickness than stock handle bar and the heated grip will slide on easily. I did it on a WO578 Wild One set of 1 1/4 bars.
thanks for all the info guys. this has turned out to be a bigger headache than i realized. last bars i changed were on a sporty and the UL is a completely different beast. i bought a set of wild 1's 578's off amazon today. their site is useful and informative and the faq answered my qeustions before i asked. forum memebers seem to like them so i feel pretty confident in ordering them blindly. i hope to get some pictures of the install and will post them up when i'm done.
