34 MPG Road King Stage 1 PV
Is it possible to improve my MPG's without sacrificing great performance? I'm only getting 34 MPG's. I ride through about 15 miles of hills 65 mph and 30 miles of Frwy 75-80 mph on my commute. I feel like 34 is really low but the bike runs great. Any help would be appreciated especially from Fuel Moto.
contact FM, you should be seeing 40+
it could be that overall it is wasting gas, or there could be just a couple of places where it is really wrong.
gas alone does not equal performance ( other wise we'd all be riding around with the choke pulled)- the correct amount gas and the correct air and spark timing all in combination make power.
I will see 34 but that takes steady 80~85 MPH
Mike
Mike
lionsm13 (03-05-2017)
My Ultra is outfitted like your King except the added lowers. I used to get 40-42 with stage 1 and stock headers with slip-ons. Mileage dropped to 38 after replacing stock headers with True Duals (same slip-ons). Now with Stage 2 cams and same exhaust it's dropped to 33-36 depending on throttle position as with the cams I'm running a bit more aggressive.
I'd say you should be a bit better than that.
You will fill out all of your bike info as well as what the bike is doing, be sure to attach a copy of your current map and if you have any datalogs that will help too. We will take a look at everything and email you an updated/revised tune. For reference most 103 Stage 1 bikes will get in the upper 30's to low 40's for mileage; this is of course relative to conditions, load, riding style, etc.. It sounds like you are a bit lower than normal but it shouldn't take much to get it up to where it should be.
BTW, sounds like you have a commute that most would die for
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The best route to go would be to use the Fuel Map Revise from on our website https://www.fuelmotousa.com/p-33537-...-services.html
