Round 2 - Primary/trans mainshaft seal repair
Here is a pic of that seal and where it goes:
I suggest you replace all the seals on the transmission while the inner primary cover is removed:
Quad Seal
Pulley Spacer
Big Oil Seal
Shifter Shaft Oil Seal
Main Drive Gear Oil Seal
Inspect the shift lever splines and the shifter shaft splines carefully, and when you reinstall the shift lever use a new bolt and make sure it is tight.
OP: What model year transmission is this?
That seal is leaking, you can see transmission lube leaking between the main drive gear and the mainshaft:
Quad Seal
Pulley Spacer
Big Oil Seal
Quad Seal
Pulley Spacer
Big Oil Seal
5 speed trans.
Pulley spacer? Is that the SS part with the chamfer? Why should I replace this?
Looks like the IPB sleeve wasn't in all the way.. Also the Pink spoo seems to be sayin' the mainshaft seal in the main drive gear ain't doin' it's job.. I'd check for play. It's possible the mainshaft needles have walk in. Also it looks like the mainshaft seal is missing but it's hard to tell.
