Confusedscot
Confusedscot
Totally Confused .com
Replaced Stock Pipes with S&S slash cut Slip-ons ..result = popping on the on the down so after seeking some advise i get myself a power commander 5 but dynajet have no data for the S&S slipons with stock intake in fact i cant find any data for S&S can i close match to other slipons is so and ideas
2002 softail fxst
2002 softail fxst
Popping on closed throttle is 99 times out a 100 down to a poor seal in the exhaust system, allowing air back into the system and igniting. Make sure the headers are tightened to spec, and if you used the old muffler clamps on the slip ons, get a new set. They are a one time use item.
A smear of copper grease on the muffler to header join helps 2 ways. Easier to remove next time around and helps to seal.
confusedscot (02-27-2017)
