Picking up 87 Tour Glide on Sat. What to bring?
As to tire age, check the last group of numbers on the DOT - if it's 4 digits (it should be), the last two are the year. (The first two are the week).
lwbdriver (03-29-2017)
Thanks for the interest and advice. Can't wait to get it home and take a real close look. Hadn't thought of the bearings and seals. Good advice. I am sure if I do a search I can find a technique to determine the condition of the belt, right? My Sportster was a cinch to work on, but this might be a bit more complicated because of the fairings and extra electronics, etc. Sure looking forward to it.
By the way, the PO says that the cloth seat it has is original from the factory. Did HD really have a cloth seat as an option back then?I have never seen one before.
One more thing to check - rebuild the carb. The float and seals can get old sitting in nasty gas and can crack and leak. I had an '81 that worked great for a good month, until I was at a bike night, and the float stuck open while I was inside... I came out to a giant pool of gasoline under my bike.
Don't recall ever coming across a cloth seat, so include that in the photos your post when you get back home. Have a good gentle trip.
