Whining / whirring noise 07 street glide
Old 03-28-2017, 11:27 PM
Vasilis's Avatar
Vasilis
Vasilis is offline
Default Whining / whirring noise 07 street glide
Good day to all,
My 2007 street glide has 21000 miles and I am starting to hear a whining / whirring noise only if the bike is cold and at the following circumstances:
1. The bike is just rolling with 1st or 2nd or 3rd gear at straight or downhill (no accellaration / throttle)
2. While in neutral or if I will hold/engage the clutch no sound can be heard.
Any ideas of what might be?
gear / transmission berrings have been changed.
also new lifters, 106 BB kit, cam plate/oil pump and cam bearings changed.
VPC installed and noise still there.
Assume that it may be the primary compensator or chain adjuster however I am not sure.
Vasilis
Old 03-29-2017, 12:43 AM
bellmnbell's Avatar
bellmnbell
bellmnbell is offline
The compensators on these bikes have known issues. The attached photo is my failed compensator, and looks VERY similar to others with the same failure. The "whirring" noise you are hearing may be this failing component.
Old 03-29-2017, 01:09 AM
Vasilis's Avatar
Vasilis
Vasilis is offline
Assume that the solution is to purchase the S.E compensator and a new H.D chain adjuster for piece of mind.
Old 03-29-2017, 05:36 AM
pingman68's Avatar
pingman68
pingman68 is offline
+1 on the compensator. I had the same style rotor and original style comp on my 08, but since going with the Baker comp and manual tensioner those sounds are gone. Much quieter overall.
Old 03-29-2017, 07:13 AM
lp's Avatar
lp
lp is online now
Received 2,717 Likes on 1,545 Posts
If the noise goes away when you pull in the clutch, it's usually the inner primary bearing (IPB); however, if goes away in neutral too, it may be something in the trans.
Places to check anyway.
jgcable
08-11-2014 06:15 PM
Plow64
11-12-2011 06:37 PM
paulhog
08-10-2010 09:40 PM
chiefparry
10-01-2009 06:46 PM
kissfan
Shovelhead
06-04-2007 09:50 PM
Quick Reply: Whining / whirring noise 07 street glide
