Belt tension
Belt tension
I have removed and reinstalled the rear wheel on my 06 RK. I marked the adjuster pieces (slim piece of metal on each side of the axle used to move the wheel forward and backward that I can't remember name of) with a sharpie so I could reinstall in the same position. Of course everything is greasy and my marks no longer exist. According to the service manual I should have somewhere in the neighborhood of 1/4 to ?3/8? Inch of play in the belt under a ten pound pressure test with the wheel off the ground. (Whatever the correct range was I installed inside the range)
I adjusted the belt to those specs using a slim metal ruler and by guessing the pressure. Then I bought the harley tool that tells you what ten pounds is and I guess I'm a pretty decent guess.
Anyway, and despite following the service manual, I can't help but wonder if it's too tight. The belt didn't feel that tight prior to removal. And nearly every YouTube video describing this process has the belt being raised to just about halfway up the built in measuring marks on the bike. Mine only reaches between the start of the integrated marks and the halfway point under ten pounds of pressure.
I'll attach a pic.
Am I good to go?
sorry for the lack of specific and detailed info.
I'll attach a pic.
Am I good to go?
defer to your manual- my manuals say wheel on ground!
the evo says with rider a certain amount of deflection...the twin cam another spec entirely.
some guys twist to 45º
I use my fingers- I know what 10# is- but I always check manual for specific method and deflection spec for each year/model bike
I've done my 07 RK many times (currently at 48K miles, and rear tire lasts 5K for me) with bike on jack (per service manual, wheel off the ground), using the H-D tool.
Your photo and description look EXACTLY like the amount of deflection I see after I've pissed around with it to make it exactly right. Bike runs properly, feels right, belt still looks good.
I say you're just fine.
Thats exactly how I tested myself to make sure I was getting accurate results. But it was awfully difficult trying to keep my hand on the base while moving the little counter weights back and forth
