2002 Ultra Classic starting problems
you need a wiring diagram and a basic understanding of the primary and secondary starting circuits.
If these terms are not familiar to you- just get to a tech before you make worse or conceal a problem from them.
the green wire IS the primary circuit and supplies 12volt to the solenoid plunger to close the contact switch and make starter run and engage the ring gear.
you can make an emergency jumper wire with a terminal on one end- put this where the green wire was...touch the other end to the battery + or to the recessed plug on a battery tender pigtail- and the starter WILL run
make sure you are in Neutral or the bike will skitter across the driveway and fall over
or a plunger type solenoid cover from any of the catalogs for $50 will bypass the primary circuit- push the plunger and start
mike
mike
