Did I just overheat my bike?
I got stuck in traffic for a while when my Engine Check Lamp came on. I knew the bike was getting hot and the traffic was thinning out. Just then the lamp came on. Just then I was able to get upto speed and the lamp turned off roughly 3 minutes later.
Does the Engine Check Lamp reflect overheating? I'll check any error codes tomorrow with my TMax software.
Also I didn't hear any knock or notice any rough running. As a precaution, I'm going to change the fluids anyway since I already have 1500 miles on them.
So, did I overheat the engine? Did I do any damage?
RE: Did I just overheat my bike?
I had the exact same problem last night as I hit a wall of freeway contruction traffic and heated it while trying to get through it. My light came on, I killed it for 5 minutes, then got the hell out of there. I was wondering the same thing and posted info but no feedback from anyone else. I am wondering what temp the Thundermax Module is set to flash the check engine light at cause I have the T-Max as well. I am guessing 300 degree head temps?
Anyone know for sure?
Well I just went out and read the diagnostics from last night. Didn't see any error codes but did see some high head temps in the logs. It showed hitting 344 degree's twice. One must have been last night, and it might have gotten that hot once last week as I did get into another snarl last week but didn't notice any lights being on. That was daytime so that might expalin, but that's hot in either case. I think oil tempis somewhere near 75 degree'slower than actualhead temp.
Gotta love this technology. Now just to figure out how to avoid traffic snarls around here.
Yikes! Yeah those are some high temps for sure. The bike seems to run OK though now huh? What type of oil are you running? IMHO that's where the advantage of running synthetic oil comes into play - the most extreme conditions like that. Where conventional oil may fail, the synthetics take it in stride...
1 Post
I see you guys are riding baggers with fairings. Dump the useless air temp gauge and install an oil temp gauge. Its the best mod I've done on my 01 Ultra. I can monitor the oil temp and before it gets too hot I can pull over and shut 'er down to cool off. It's unlikely that you did any damage, but changing the fluids is definately a good idea.
ORIGINAL: bikergeoff
Thanks
300 degress is not that hot for your Engine/Head temp. I have a lazer temp light that I use all the time. I used it for tunning my Carbureted Road King while I was adjusting the ignition. Your rear cylinder will run hotter then the front. My rear cylinder runs about 30-40 degrees hotter then the front. Front head is always running around 300-310 and the rear is always about 30-40 degrees hotter. I've checked alot of other Bike while out riding and they are all in the same range. Some alittle higher and some alittle lower. I wouldn't worry aout it at all. You will be fine.........
