Slight oil leak from oil filter
I just changed the oil on my 06 RK and I seem to have a very small leak coming from the oil filter seal. Anyone ever have this? I tightened it to 1/2 to 3/4 of a turn by hand after the seal touched the housing (as specified by the service manual), then tried it a little tighter and it still seeps. Maybe the oil filter itself has a leak? Should I just replace the oil filter again or is there something I else I can do to stop the leak?Thanks!
RE: Slight oil leak from oil filter
There is no reason to drain the oil as mentioned in a previous post the only oil you will lose is what is in the filter. Just pull the filter as usual taking the normal precautions that you take to keep the oil from running down the front of the engine.
Lowrida (03-31-2024)
If it is not the oil filter leaking...it probably is the housing itself. The oil filter housing is bolted to the block with three bolts and there are two o-rings on the housing. It is not that uncommon for one of those o-rings to start leaking. Do replace the filter first though.
