Power Commander Announces New Maps
Bike Model: Harley-Davidson All EFI Touring Models (Twin Cam) :
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Supertrapp 2 into 1 SuperMegs (with 20 discs), Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend Enabled, Fuel table 1 is rear cylinder
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map* Wild Pigs slip-ons, Screamin' Eagle air filter, Stock ECM, Dynojet O2 eliminaters installed, Rev Xtend enabled, Fuel table 1 is rear cylinder
· 2007:Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Kerker 2 into 1 Supermeg, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled, Fuel table 1 is rear cylinder
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map* Kerker 2 into 1 Supermeg, Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Supertrapp Supermeg exhaust (20 diffuser discs), Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Rinehart by Bub True Dual Exhaust, Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed Revextend Enabled
· 2007:Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Thunderheader 2 into 1 Exhaust, Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Revextend Enabled
· 2007:Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Screamin' Eagle Touring slip-ons (66077-06A / 66012-06A), Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled
· 2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Khrome Works HP+100 slipons , Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled
· [URL=http://www.powercommander.com/downloads/812/maps/m812-038.exe]2007: Harley-Davidson All EFI Touring Models (Twin Cam) : *Advanced Map*Rush Performance slipons with 2.5" baffles, Screamin' Eagle 103" flat top pistons, Screamin' Eagle 255 Cams, Screamin' Eagle air filter, Stock ECM, Dynojet O2 sensor eliminators installed, Rev Xtend enabled Fuel table 1 is rear cylinder [/link
RE: Power Commander Announces New Maps
Please help a newbie.. what does it mean "Fuel table 1 is rear cylinder"?
Do you have the V&H Oval Slip ons? do you like the sound? I heard a set on the highway the other day of the ovals (not sure if they were slip ons..) but the guy had an o7 Ultra and was cruising at about 70 mph and they sounded pissah!
Also wondering of the combo of the V&H ovals, the PCIII and the K&N cooled things down for you a bit? Are you running a standard map?
tnx.. sorry for all the questions.
fastolds
04-24-2007 12:25 AM
