ThunderMax firmware
RE: ThunderMax firmware
From within the program for one. Use the drop down from either Configure or Tools(can't remember as I'm at work) and see Smartlink IV Firmare Update and let the program log onto the Zipper's Server to retrieve the update........................if it shows something like Thundermax.......06-19-12(again, something like this)........that's the latest one and you are probably already running it.
It came back "no updates available for download" Guess I'm good to go. The reason I ask is I'm running Map 384 and there is an updraded map for my configuration, map 393 (richened AFR targets 14.4:1 to 13.8:1 between 1024-20something) Bike has 900 miles on it,. other then a little decel pop, bike runs great. Would it be benifitail to upgrade? thx, Putt
ORIGINAL: Puttnutt24
If you choose to reload the newer map, follow THESE INSTRUCTIONS to the letter and all should be fine.
