rear tire replacement
Need to replace the rear tire on my 06 Ultra and was quoted $250 at the dealer today. Seems like a lot for a rear tire, especially on a bike. I went to American Motorcycle Tire and saw they have the D402 for $116. Seeing as the tire is tubeless, there should be no need for tire strips, right? Thinking of doing the replacement myself. Seeing as I did the 95" kit with gear driven cams myself, I would think changing a tire would be a piece of cake. Anyone who has done this, any advice?
RE: rear tire replacement
I kind of thought so. With shipping, the tire will be $127 to the house. I will use a c-clamp as a bead breaker andwill check the local auto parts store for tire irons and rim protectors. I figure I will mark the current placement of the rear axle before removing which should get me where I need to be upon replacement. Should be able to use the rear axle and some blocks to figure out placement of wheel weights for balancing purposes. Does this sound like I am on the right track?
I just put a new rear tire on last week, and it is very easy to do.
$108 for the tire at the local dealer, and they charged me $45 to mount&balance it on the rim and dispose the old one and of course state tax. Picked up a new pair of rear brake pads for $42 and put those in while I had it apart. When it was all added up, it cost me $200 for the new rear tire and brake pads...........and I did all the work myself in about 1 hour total.
Steve
Steve
Usually if you use the same type tire they are not to bad for being out of balance. Be sure tread is in right direction and dot on tire is at air valve and all should be fine. I usually take my wheel off and take it and tire to one of the neighborhood shops and they change it for about $20. Saves alot of time and money. Good luck either way.
I'll have to check the local dealer for the tire price. I will look at the brake pads but the bike has just over 10k and almost all of that is highway so they should be good. Any other tips Steve?
ORIGINAL: maineultraclassic
Steve
Steve
Gonna use theDunlop D402 which is what is presently on the bike. Guess I won't pull the wheel weights until I get the new tire on. Pretty much only shop in town is the local HD shop. Shouldn't be too hard to replace. I look at it as a learning experience. LOL
ORIGINAL: flashprez
