Stock EVO 80" I want more out of it?
Old 08-19-2007, 12:11 PM
phat96's Avatar
phat96
phat96 is offline
Default Stock EVO 80" I want more out of it?
Hi guys I'm looking to add some umf to the stocker engine do I go with andrews cam #EV 23 or EV #27 ? do need new push rods and are new valve springs needed? am I missing anything.I want more mid torque but I need to control cost.
I have true duels and hi out put mufflers a hypercharger and a rev tech DFO already installed.
Thanks
Old 08-19-2007, 12:32 PM
jmacdonald5's Avatar
jmacdonald5
jmacdonald5 is offline
Default RE: Stock EVO 80" I want more out of it?
When I had my 98 Fatboy I did the standard "Stage 1" if you can call it that, that most Evo owners did back then. EV-27cam, A/C, and pipes. Bolt-cut the stock pushrods, and go with adjustables. You don't need to mess with the springs as those cams aren't real high lift.You'll gain about 8-12 HP, depends mostly on what pipes you run.
Old 08-19-2007, 12:36 PM
smknflms's Avatar
smknflms
smknflms is offline
EV 27..buy a set of adjustable or easy install pushrods, it will make the job a lot easier, springs should be fine.
See:
http://www.nightrider.com/biketech/hdcaminstall00.htm
Go thru the list in the box at left side of page.
Later
Old 08-19-2007, 01:08 PM
MACK's Avatar
MACK
MACK is offline
INCREASE DISPLACEMENT,DO SOME HEADWORK AND PROPER CAMS.
Old 08-19-2007, 01:09 PM
hoz88's Avatar
hoz88
hoz88 is offline
I did the EV27 and high comp pistons on my lowrider. It ran good!
Old 08-19-2007, 03:20 PM
phat96's Avatar
phat96
phat96 is offline
Thanks guys, looking forward to getting into it. Thanks for the advice.
Old 08-19-2007, 03:44 PM
Tuco's Avatar
Tuco
Tuco is offline
Had a '98 RK and was in the same boat as you. I just wanted enough were I wouldnt be in second gear going over the high mountain passes here in Colorado. I sent the heads off to Bad Boyz in Maine to have it decked, polished and whatever other magic they did. Also put in a ev27 but a ev23 would probably work better. Adjustable push rods, gasket set are all you should need. 80 hp / 86 tq. Got 50 mpg and ran gooder. All for about 5-6 hundred bucks.
RoadBurner69
08-28-2014 08:17 PM
magnum629c
01-07-2013 05:31 PM
blair
10-15-2011 09:43 AM
Jesse_the_kid
03-11-2009 09:53 PM
fiddledicksr
Exhaust System Topics
11-07-2006 12:38 PM
Quick Reply: Stock EVO 80" I want more out of it?
