Stock Air Filters
Old 08-19-2007, 01:28 PM
mariner227's Avatar
mariner227
mariner227 is offline
Default Stock Air Filters
Is there an aftermarket air filter element that will fit in my stock HD Air cleaner housing that will allow the bike to breath better? I'm am going to stay at 96" and already have a pc3 and different pipes. Any suggestions would be helpful. Thanks in advance. 07 FLHTCU
Old 08-19-2007, 01:31 PM
Cryptoboy's Avatar
Cryptoboy
Cryptoboy is offline
Received 3,877 Likes on 1,415 Posts
Default RE: Stock Air Filters
I believe there is a Screamin Eagle filter that is made for the stock cover. Also K&N makes an upgraded filter. (at least I think they used to). You should be able to use the round SE or Big Sucker I (Arlen Ness) and keep the stock front of the cover (you'd lose that backing on the stocker, cuz they would have a new backing in place.
I know for the TC88 that was true, not 100% that holds true for the 96 inchers, but don't see why that would be that drastically different.
Old 08-19-2007, 06:22 PM
mariner227's Avatar
mariner227
Thanks! I'll check the k&n site.
Old 08-19-2007, 07:03 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
If you're trying to complete a Stgae 1 then you'll need to change the complete air system - not just the filter... Just installing a K&N on to the stock system is not the same...
You can go with:
Ness Big Sucker (more bang for the $$$)
SE Performancxe Air Kit
K&N Air Kit
Old 08-19-2007, 07:16 PM
mariner227's Avatar
mariner227
So CAl Pappy
I already have the k&n but recently removed it along with the pipes and pcIII for warranty work. The slipons and pcIII are simple but the ac is a pain.I'm running the stock ac now with the supertrapps and pcIIIand really don't notice a difference. I had the bike on a dyno to get the correct mapwith the K&N ac on. It's probably a tad rich now. I may take it over and have it put on the dyno again to compare numbers. I'll bet there is not much difference running the stock ac.
Old 08-19-2007, 07:22 PM
SoCal_Pappy
The Stage 1 Air kit allows better air flow and vents the heads better... You can always check to plugs to see if your running rich or lean... Cheaper then a Dyno again
Old 08-19-2007, 07:30 PM
mariner227's Avatar
mariner227
Very good point! But, I still would like to see the numbers. I've heard from a few guys that unless you do a major build that you don't really need o change the ac. It would not be the first time that someone blew smoke up my butt to sell me something.
Waterman1
Milwaukee Eight (M8)
03-19-2017 09:55 PM
rob7711
11-18-2009 11:59 PM
arkieollie
01-08-2007 06:35 PM
flstfjeff
09-22-2006 01:36 AM
Varooom
Exhaust System Topics
13
05-06-2006 03:52 AM
Quick Reply: Stock Air Filters
