Oil Pressure
Old 09-07-2007, 09:43 PM
hennyk's Avatar
hennyk
hennyk is offline
Default Oil Pressure
I have a 07 96 cubic inch engine. My oil pressure drops to almost nothing when idling after riding in hot weather. Is this normal?
Old 09-07-2007, 09:48 PM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
Default RE: Oil Pressure
Yep!
Old 09-07-2007, 09:55 PM
tjmac49's Avatar
tjmac49
tjmac49 is offline
ORIGINAL: hennyk
2007 Owner's Manual, pages 41-42: "Engine oil pressure will normally vary from 5 psi (34 kN/m2) at idle speed ...."
Old 09-07-2007, 10:16 PM
hennyk's Avatar
hennyk
hennyk is offline
Thanks!!!!
Old 09-08-2007, 08:44 AM
HogBack's Avatar
HogBack
HogBack is offline
hennyk.... just one more thought... a HD uses high volume not higher pressure to lubricate... so if we are use to seeing good 'oil pressure' we panic as a HD does not require that high oil pressure...
Hogback
Old 09-09-2007, 01:45 PM
moxonbi's Avatar
moxonbi
moxonbi is offline
The same thing is happining with my 08 ultra. Thanks for the info.
Old 09-09-2007, 01:56 PM
drdiesel1's Avatar
drdiesel1
drdiesel1 is offline
That`s why they idle @ 1000 RPM. Anything under that and the stock oil pump will not supply sufficient oil/pressure and could cause damage.
If you tuning your bike with A/M stuff andsetting your idle below 1K for the Potato - Potato sound, you should upgrade your oil pump. IMHO...[8D]
Old 09-09-2007, 02:04 PM
PRrdglide's Avatar
PRrdglide
PRrdglide is offline
If you are caught in hot weather and in traffic shut the bike down and let it cool off. It needs moving air to keep it cool. This is were syn oil comes in to play ithandles and dissipates heat better This is not only for the new bikes but any air cooled motor.
Old 09-20-2007, 05:26 PM
lagonia's Avatar
lagonia
lagonia is offline
5th Gear
I dunno guys. I had the same problem so I decided to replace my stock oil pressure relief spring with a Baisley spring. At idle, cold I get 32PSI and when fully warmed up I get 18 PSI (at 1000RPM). At 2000RPM (warm) I get 35PSI, at 3000RPM (warm) I get 45PSI. This is measured via a mechanical oil pressure gauge (Jeerzees customs) and not through that idiot sensor that comes with the bike (2003 Ultra Classic). The engine is nice and quiet now and the performance has not changed from before going to the Baisley spring.
Old 09-20-2007, 06:17 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Oil? What oil?
Quick Reply: Oil Pressure
