Lube Clutch Cable?
Old 09-14-2007, 07:41 PM
BrianDamage's Avatar
BrianDamage
BrianDamage is offline
Default Lube Clutch Cable?
Trying to finish up my ape install, and will be adding new brake lines, throttle cables and clutch cable.
Service manual mentions lubing the throttle cables, but I'm not seeing anything that says to lube the clutch cable...is that right>?
Old 09-14-2007, 08:28 PM
raftgyde's Avatar
raftgyde
raftgyde is offline
Default RE: Lube Clutch Cable?
Lube it too.
Old 09-14-2007, 08:35 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I'll second that,lube it two.
Old 09-14-2007, 10:04 PM
Tech2's Avatar
Tech2
Tech2 is offline
ORIGINAL: BrianDamage
You are correct. I also found it odd that there is no mention of 'how to' in either the manual or on the 'Fix My Hog' DVDs.
Old 09-14-2007, 10:16 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
I have this little tool I bought when I was racing bikes, called a "cable luber"???
its small rectangular shape metal ,hollow, with rubber in the middle, the steel cable slides in,, you tighten the thumb screw and it squeezes down on the rubber,cable and cable housing, then you get spray lube and one of them straws, stick into the hole on the tool, spray, (i use silicone) the lube is then injected down your cable.
Old 09-14-2007, 11:07 PM
mrbadlands's Avatar
mrbadlands
mrbadlands is offline
Another way to do it, would be grab a piece of clear tubing and put onto the end of the cable. In the tube, put your favorite lubricant and then use air pressure to push the lubricant into the clutch cable.It works for me on other applications.
ORIGINAL: electaRICK
Old 09-15-2007, 12:03 AM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
I had one of those things long ago but now I can't find it. Where did you get yours? Not from my garage, I hope. [8D]
Old 09-15-2007, 07:18 AM
dog155's Avatar
dog155
dog155 is offline
Can you feel the difference after lubing the clutch cable with Silicon?
Old 09-15-2007, 07:38 AM
electaRICK's Avatar
electaRICK
when I did it the first time on the Dyna,,,you would have thought I installed one of them EZ clutch kits.
yes it helped,,,
I don't like using oil,, well on the dirt bikes it gathered to much dirt.
so I got used to silacone,,, besides I get it ,,"CHEAP"
Old 09-15-2007, 07:49 AM
1flhtk4me's Avatar
1flhtk4me
I bought one of the Lockhart-Philips cable luber.After I tried to use it,I came to the conclusion its to small for the cable.Now it's just hangs on the wall.
Quick Reply: Lube Clutch Cable?
