Any way to make Rinehart True Duals louder?
Old 10-14-2007, 05:03 PM
dietdewboy's Avatar
dietdewboy
dietdewboy is offline
Default Any way to make Rinehart True Duals louder?
Is there any modification I can do to this system to make it louder? Baffle modifications? or something. I'm not interested in other systems, this isa new system I just bought and installed last week, so its what I have to work with.
Dave
Old 10-14-2007, 05:07 PM
SpikeCT's Avatar
SpikeCT
SpikeCT is offline
Default RE: Any way to make Rinehart True Duals louder?
your kidding right? If its not loud enough do an engine build and then its loud when you crack it. I like them as I can take it easy and not wake up the entire neighborhood. Of course Im rnning TD.
Old 10-14-2007, 05:56 PM
kingtut73's Avatar
kingtut73
kingtut73 is offline
buy a thunderheader
Old 10-14-2007, 06:03 PM
DonnyI's Avatar
DonnyI
DonnyI is offline
Pull the baffles and see how you like it.
Old 10-14-2007, 08:11 PM
SkyDriver's Avatar
SkyDriver
SkyDriver is offline
Pull the baffles and use a step drill and a drill press to enlarge the holes in the baffle to whatever size you like but take it easy at first. Big difference. Probably have to use a slide hammer to remove the baffles and a rawhide mallet to reinstall them. Pain!!! Good Luck.
[IMG]local://upfiles/25366/37A0E74BF69B42E5BB9F4346FBD5254C.jpg[/IMG]
Old 10-14-2007, 09:14 PM
Ultrasweet's Avatar
Ultrasweet
Ultrasweet is offline
WHY?
Old 10-14-2007, 09:16 PM
CSI's Avatar
CSI
CSI is offline
Just take em off and run open pipes.
We will patiently await your next thread: "Any way to beat a loud pipe ticket???"
Old 10-14-2007, 09:19 PM
Ultrasweet's Avatar
Ultrasweet
What I like about my TDs is they are more than loud enough when gettin on it and have a nice mellow note when cruising. T.
Old 10-14-2007, 09:55 PM
johnltex's Avatar
johnltex
johnltex is offline
I have a used set of performance baffles for them I'll sell for $50 shipped, they open them up some...
Old 10-15-2007, 03:05 AM
dietdewboy's Avatar
dietdewboy
Has anyone tried the "Drill out method", that seems interesting to me. As far as baffles go, I contacted Rinehart about there preformance bafflesand there responce was "The way the baffle squelches down at the end brings up back pressure that improves low end mid range but also quiets ever so slightly.
most guys get the Perf. baffle because they think it will get louder. I just wanted to make sure you new it wouldn't. Thanks Jim" As far as a Ticket goes, I live in New Hampshire the noise law is 106db, way louder than the rineharts are. [/align]
Quick Reply: Any way to make Rinehart True Duals louder?
