Cam Bearings...FAILED!!!!
2006 SG...
Just had Cam Bearings replaced under warranty, bike had 29.7k on it when they failed, the cam tensioners were in great shape, they looked like they could have gone another 30k without a problem.
Took the dealer aboutthree days to figure out where the noise was coming from and then a day to get the parts and install, I asked if I could have SE203's installed and pay for the differencebut the lead tech said that he didn't want me to get into warranty issues later on?
When I went to pick the bike up I was handed a bill for $80 bucks? They said that the oil and filter arenot covered under warranty...so lets see; cam bearings failed under waranty and put metal debris inMY oil and filter AND I HAVE TO PAY FOR THAT?
Anyone else have cam bearing failures under 50k? I thought88 Twin Camwas a 100k engine? I'm startin' to have my doubts...[:'(]
RE: Cam Bearings...FAILED!!!!
I know I will take heat for this, but
File a written letter of complaint with
Lori Oelhafen at the MOCO.
then if it doesn't work file a complaint
on line with the Federal trade Commission.
Explain your case.
Moco won't respond positively to your complaint
to them. But enough complaints via the FTC, then they
will.
Explain your case.
will.
ORIGINAL: fryeca
2006 SG...
2006 SG...
ORIGINAL: Mountainkowboy
One out of how many thousand bikes doesnt make it a trend!
ORIGINAL: xxxflhrci
Maybe not, but HD didn't do there homework on the Twin Cam's cam chest from the beginning. There have been far too many failures of bearings, tensioners, cam lobes wearing off, oil pumps going out, oil pumps sumping, and so on. There have been plenty of updates to fix the problems, but they seem to pop back up far too often. If I had an '06, I'd be pissed about a cam bearing going out when the problem was supposed to have been fixed after the early '00 model year.
Motorcycle Consumer News did a survey on the Twin Cam 88 owners. While most of the cam bearing problems occurred with the first year until they changed the bearing design, they did find a fairly significant number still crapping out at various mileages, with no patterns. The tensioner failures were also mentioned. Definately a weak point for the design.
ORIGINAL: fryeca I asked if I could have SE203's installed and pay for the differencebut the lead tech said that he didn't want me to get into warranty issues later on?
Second thing................$80 for an oil change??
Steve
ORIGINAL: dstockton
2) The large sum of money set aside (charged off) to fit "future cam bearing problems."
Eighty bucks for an oil change seems a little steep, even if it was all the work that was done. Aside from that, though, at 29.7k (assuming miles) it's time for an oil change anyway, right? So how much do you really think the failed bearing(s?) wrecked you oil/filter? Did they use up the last 2% of its life, maybe?
